Hello there,
I have recently started noticing that sounds that get played though my speakers sounds is being replayed through my microphone so anyone on the other end of somthing like Team speak can hear it. I think it is software side because I have treid it on my mums laptop and it's fine (I use a Razer Kraken pro)
If anyone can help me I would appreciate it a lot. if you need any more information just ask. Thanks.
https://linustechtips.com/topic/36802-speaker-sound-comming-through-microphone/
It's software. Microphones cannot output audio, except for old ones. You're using external speakers, correct? In line with what Glenwing said, use headphones.
What audio? Realtek?
Use headphones.  That's usually how everyone else solves it.  That's why you see tons of "gaming headsets", but never any "gaming speakers"...
What about corsairs?  :D
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
microphones are designed to pick up sound, if sound is around its going to transmit it, if you have a desktop mic get a shield for it that covers the back and leaves the part you talk into open, or just turn down your speakers/buy headphones.
The sounds are comming strate though the speakers its software side because it's not happening on a different computer
did you hear the feedback?
I mean, when you speak, you also hear your own voice.
sorry I'm not really understand english .
and what your OS dude?
Where am I? What is this place?
Windows 7 HP
And no it's my Mic picking up the sounds my computer make that is the problem
Windows 7 HP
Try this,
Go start menu and type "Realtek HD Audio Manager" choose the option.
Under the Microphone tab; Microphone Effects, make sure that the Acoustic Echo Cancellation is checked.
 CPU: Intel i5-6500 @ 3.6ghz | Mobo: Gigabyte GA-B150M D3H | RAM: Avexir Core Series 8GB (2x4GB) | Gfx: Zotac GTX970 Amp! Omega | Chasis: Phanteks Evolv ATX  | PSU: Seasonic M12II Evo 620W | SSD: Samsung Evo 850 250GB | HDD: WD 320GB |
CPU Cooler: ID-Cooling Frostflow 240l |
FANS: Corsair SP120 rear exhaust | Keyboard: Ducky Shine DK9008S | Mouse: Corsair Vengeance M60 | OS: Windows 10 Pro 64bit
Alternatively, try disable or enable Stereo Mix.
http://www.howtogeek.com/howto/39532/how-to-enable-stereo-mix-in-windows-7-to-record-audio/
Hope this helps.
