I need HELP!
Go to solution Solved by YoYo155,
This oughta' do it:
http://www.sevenforums.com/tutorials/292068-make-windows-7-bootable-after-motherboard-swap.html
Good night and good luck, I'll check back in the morning.
You change your CPU from one company to another?
https://linustechtips.com/topic/36751-i-need-help/#findComment-471903
What are the settings for your drives in your BIOS? When changing motherboard they may be changed and will have to be what the old one was.
https://linustechtips.com/topic/36751-i-need-help/#findComment-471904
SATA is the interface. But it might be set to AHCI, rather than IDE. But is the CPU company the same? I.E. Still Intel or AMD?
https://linustechtips.com/topic/36751-i-need-help/#findComment-471938
Okay. Then most likely it's a setting in the BIOS.
https://linustechtips.com/topic/36751-i-need-help/#findComment-471951
So what can I do to fix this.
First confirm that is really what is happening.
At boot hit F8 a number of times, until you get to a list called "Advanced Boot Options"
2010-05-17_070306_Advanced_Boot_Options.
Then highlight "Disable automatic restart on system failure"
and hit enter.
Now what that did is if you're getting a Bugcheck a.k.a a BSOD
the system will not reboot.
it will allow you to at least read what the error is and wait for user input or in other words until you force
it to restart via the reset button.
Then post the details back here (if there are any) and we'll go from there.
https://linustechtips.com/topic/36751-i-need-help/#findComment-472013
BTW is it normal for a 4770k to ideal around 50c
Ambient temperatures?
https://linustechtips.com/topic/36751-i-need-help/#findComment-472402
Depends on the load and how well your cooling is
Intel 3570K - MSI GTX 660Ti 3GB OC Edition - 16GB Corsair LP RAM - ASRock Extreme4 Motherboard - Corsair HX850 - Adata Premier Pro SP900 120GB SSD with Windows 7 - Seagate Barracuda 1TD HDD - Seagate Barracuda 500GB HDD - Thermaltake Frio CPU Cooler - CM Storm Enforcer Case - Macbook Pro Early 2011 Laptop
https://linustechtips.com/topic/36751-i-need-help/#findComment-472420
Wait does this tool reset my product code
Most likely, no.
https://linustechtips.com/topic/36751-i-need-help/#findComment-472483
