Hola!
I'm going to build my first PC after a couple of months and I have already chose the parts, so I decided to ask for your opinion.
  • Intel Core i7 5820K 6 Core
  • 64 GB DDR4 RAM
  • MSI X99S SLI Plus
  • Samsung EVO 850 250GB (4x)
  • XFX XTR 750 Watts
  • NVIDIA GTX 980 Graphics Card
  • Case? Haven't decided yet
  • Also what do you think about Dell P2715Q? Will it worth the money? Are there any 4K monitors out there that are much better and have better sharpness?
https://linustechtips.com/topic/366936-first-build-what-do-you-think/
Maybe knock off 1/2 or 3/4 of the ram if you don't need it.. Also get only 1 or 2 SSDs and consider dual GPU if you want to throw money somewhere that'll give you more FPS at 4k.
2500K @ 4.5GHz | ASRock P67 Extreme 6 | 16GB Ram | GTX 750 Ti | 250gb SSD | 1TB+2TB HDD | 720W CoolerMaster PSU | Essense STX Sound Card | Define R5
