My friend has an NZXT S340 and is planning to mount a Corsair H100i GTX on the front. Should he get 2 SP fans for push and 2 AF fans for pull? Or just get 4 SP fans for push and pull?
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/366860-fans-for-pushpull/
4 sp fans, also i wouldn't change them unless he has a problem with them, temps are decrease all that much, noise is the biggest reason to change fans. also vardars are very good sp fans.
follow your post so you see when we reply. @cheeze_tartz
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968408
Alright, thanks. I don't usually follow topics, as it creates a lot of notification spam.
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968423
ah, well we would like you to notice us senpai but, i understand. also bequiet and noctuas and cougar vortex are all good too.
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968438
You can't push/pull in the S340. There is not enough space because of the cable cover. If you can remove it you might be able to but you would be getting close to the motherboard and connections (24pin, sata, usb3)
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968444
aww  forgot about that cable cover. Yes, you can remove it but his GPU is freakin' huge. Can you at least do push with the cable cover?
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968586
Make sure to get the high performance.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968656
Yeah you can do one set. I have a Raijintek Triton (32mm rad) in mine with fans in pull and the back of the fan just fits in front of the cover. The H100i GTX is 30mm thick apparently so it should be fine.
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968724
Corsair PE's are unnecessarily loud and not worth getting.
Why push/pull in the first place?
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4968907
Little bit lower temps?... I think?
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4974927
It doesn't make much of a difference for such a thin rad.
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4976116
Good to know. I'll just tell him to stick with push.
https://linustechtips.com/topic/366860-fans-for-pushpull/#findComment-4976122
