Hi,
I'm not sure where to post this but i am assuming its here.        I'm having trouble with games that use the Source engine i'm getting an average of 10-15 fps and the max i'm getting is about 25 fps.
The games that i've tried with this is Garry's mod, Counter strike: Source, Insurgancy.   I've tried Lowest and the Highest. I play games like Bf:Bc 2, Max payne 3, Payday 2, War Thunder,GTA V. At high-ultra all at stable 60 fps, Fps drops to about 40-50 every now and then.
    My Specs are :  Zotac GTX 960 AMP! Edition 2GB GDDR5 128Bit (Up to date) I5-4460 3.2GHz Quad-Core (Not sure if its up to date but i recently bought my computer so i belive it is), 8GB Kingston HyperX Fury 1866MHz, 500W Cougar RX500 (Not sure if this matters)
My question is why am i getting low fps on source games I really don't understand this
https://linustechtips.com/topic/366718-source-games-problem/
man you should be getting 200-300 FPS in cs:go with these specs, this is very weird indeed..
fps_max ?
v-sync?
driver update?
Hardware: 4790k @ 4.6 GHz w/ H100i - MSI GTX 970 - Define R5 - MSI Z97 PC Mate - 840 EVO - G.Skill 2x4 GB
Peripherals: G402 - ATH-AD700x - Asus VG248QE 144 hz
https://linustechtips.com/topic/366718-source-games-problem/#findComment-4966656
