Hello all,
I've been using Vsync lately, but I've been having some issues with it.
I'm running a mix of high settings, but all the filters like MSAA, AA, etc are disabled.
When I disable Vsync, I get 80+ fps, without any framedrops below 60. However it's somehow pretty laggy, some sort of input lag.
When I enable Vsync, I usually get 60 fps, but drops down to 50-55 a lot, which doesn't make it a lot of fun.
So while my rig should be able to run these settings at 60+ fps all the time, I don't get the performance I want, if I use Vsync or not.
Any ideas?
Thanks
CPU: Core i5 4690k                                                   Motherboard: Gigabyte Z97M                     RAM: 16GB HyperX Fury Red
GPU: RX 580                                                             Storage: Sandisk Ultra II 240GB                  PSU: Seasonic M12II Evo 520W
Case: NZXT S340 red/black                                      Case lighting: NZXT Hue+                          Mouse: Logitech G502
Cooling: Cooler Master Hyper212 Evo                     Operating system: Windows 10 64-bit
https://linustechtips.com/topic/366460-gta-5-problems-with-vsync/
freesync
I don't have a freesync monitor.
Anyone else?
Anyone else?
If you're using v-sync turn it off apply and then turn it on again every time you start the game and every time you alt+tab the game. Don't know why this is happening but it works for me.
Stops this random fps drops.
