My friend is using a very very old PC with this particular motherboard:
http://www.gigabyte.pl/products/page/mb/ga-m61sme-s2l_20
The CPU that he's using in that motherboard is an AMD Athlon 3500+ (singlecore) (socket AM2).
He wants to upgrade his CPU without replacing the motherboard (too expensive).
We noticed that there's a much bigger variety of CPUs that have the AM2+ socket.
Will a socket AM2+ CPU work on that motherboard?
Or should he buy a socket AM2 CPU instead?
https://linustechtips.com/topic/366449-old-amd-sockets-need-help/
I think the difference between AM2 and AM2+ is HT speed so it should work, but might be a little slower. I'm not sure on that though, i'll edit this after looking around
Anything AM2+ should work fine, but have a slower HT speed. "Support for Socket AM2+/ AM2 processors"
http://www.gigabyte.com/products/product-page.aspx?pid=2507#sp
That motherboard doesn't have an L at the end but I was trying to find a page that was in english, to be safe you should refer to this after deciding on a CPU
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=2644
It can be expensive to find an old CPU that will work with that motherboard, and I'd suggest just saving around $200 to buy a different CPU and Motherboard since the performance gain will probably be negligible without switching out of AM2
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
i'd save more money and plan a new build.
but to answer your question : AMD confirmed that AM2 processors will work on AM2+ motherboards and AM2+ processors will work on AM2 motherboards. However, the operation of AM2+ processors on AM2 motherboards will be limited to the specifications of Socket AM2 (1 GHz HyperTransport 2.0, and one power plane for both cores and the IMC). AM2 processors do not benefit from the faster HyperTransport 3.0 and separate power planes on AM2+ motherboards. As with AM2 components, AM2+ CPUs and motherboards are designed to use DDR2 RAM exclusively. source
may your framerates be high and your temperatures be low. #pcmr
There are BIOS updates out for the board so AM2+ CPUs will work with it, albeit with a few AM2+ features missing as stated above.
A Phenom II x4 would be a really good step up, but I'm not sure how the motherboard would cope with higher TDP CPUs like the x6. If you can find one for cheap and update the BIOS, it'll massively speed up that machine
LTT's fastest Valley 970, slowest Valley Basic and Extreme HD scores
Desktop || CPU - i5 4690k || Motherboard - ASUS Gryphon Z97 || RAM - 16GB Kingston HyperX 1866MHz || GPU - Gigabyte G1 GTX 970 *Cough* 3.5GB || Case - Fractal Design Define R5 || HDD - Seagate Barracuda 160GB || PSU - Corsair AX760
A Phenom (Agenda core) would work fine in that board, but I can confirm from experience that the hyper transport speed will be capped. It won't seriously hamper performance in most cases.
Your friend could just toss in an Athlon 64 X2 or an FX 60 series. Those are monsterous dual cores even today. Built a small system for a friend on a tight budget, even runs AC Unity surprisingly well.
All are available on eBay for very cheap now.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
The AMD Athlon II X4 640 should work, It is a AM2+ CPU.
But id rather recommend a AMD Athlon 64 X2 6400+ for safety.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
Dem nvidia sata ports.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
If you are looking at replacing the processor, I would suggest getting a used one, from ebay or something, and try to make sure you don't overspend. Whatever you do get make sure it is supported but the motherboard. The motherboard manufacturer has a supported CPU list.
Not trying to muddy the waters for the OP, but has anyone checked out the supported CPU list? With the appropriate bios, it supposedly can support some AM3 processors? Wha? This seems off and may lead to an unsupported CPU.
Edit
ApolloX75 and harrynowl addressed that. So check the supported CPU list and update your MB bios.
Supported CPU List
Its accurate. AM3 was backwards compatible with AM2/+ but not the other way around. And AM3+ is not.
Has to do with available memory controllers. The AM2 chips are inherently born with DDR2 while AM2+ handles both ddr2 and 3 hence why they work on an AM3 board.
AM3 CPUs had a DDR2 memory controller so they can work in an AM2(+) board- but not the other way around.
Well I guess that solves that. It is counter-intuitive, being that an AM2 board can support an AM3 CPU. I just didn't think it could all the way back to AM2.
So the best CPU then would be a Phenom II X4 955 (Deneb 95w).
If AM2+ works on that motherboard, the Phenom II X4 940 would put some life back into the system.
Example: Phenom II X4940
http://www.legitreviews.com/amd-phenom-ii-x4-940-processor-review_860
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
