My pc spec
CPU: amd fx9590
Motherboard: asus crosshair v formula-z
Ram: corsair 8gb 1600mz
Graphics card: asus strix gtx970 4gb
PSU: corsair 750rm
cooling: corsair h100i
storage: 2tb seagate
os: windows 8.1
i try those things which
1.Reinstall os
2.replace ram
3.reassemble my pc
4.update my all drivers
5.scan for virus
https://linustechtips.com/topic/366306-my-pc-randomly-freezing/
You gave no information as to what happens. What are you doing on your pc when it crashes? What are the temps? What is in windows event viewer? It's probably overheating. That's a hot cpu and it shuts off once it reaches a certain temp. I have an 8350 and the same motherboard and most of my issues are with heat. What GPU do you have? What are the temps?
https://linustechtips.com/topic/366306-my-pc-randomly-freezing/#findComment-4961667
