[HELP] How to remove a menu item in your control panel
Solved by laxer,
Here it is, I am not sure if it will need elevated permissions as it is editing the registry... (I have UAC off and was lazy)
Instructions:
- Download
- Unzip the contents
- Right click on "RUN_ME" and select "Run As Administrator"
- Restart the computer
- Repeat steps 3 and 4 one more time and you are done :) (script should run twice and you should restart twice)
Tried it a few times here and was good :D (on a x64 system but, I have the lines in to fix it for x86 as well)
The reason I have you run it twice is to delete the files that may have been running the first time. Not quite sure how to force close them so I just delete what calls them then delete them <_<
