Hello, Linus Town. This is my first topic and I hope you guys can help me out.
These are my PC specs:
- MOTHERBOARD: GIGABYTE 970A-D3 AM3+
- CPU: AMD FX-8350 @ 4.0 GHz
- RAM: Kingston HyperX 8 GB 1600 MHz DDR3
- GPU: Sapphire Radeon Vapor-X HD 7950 OC with Boost 3 GB DDR5
- HDD: Seagate 1TB Barracuda 7200 RPM
- PSU: Thermaltake TR2 700W
- CASE: Zalman Z11PLUS HF1
I'm having trouble running both Crysis and Skyrim at max settings. They both run around at an average of 30-55 FPS. I know they are both GPU hungry games but the weird thing is I can run Battlefield 3 at max settings at over 80 FPS with no problem at all!
I've already tried re-installing the games, re-installing the drivers, even re-installing Windows, but the problems still continue.
I'd really appreciate if you guys could help me out.
MOBO: GIGABYTE 970A-D3 3.0 | CPU: AMD FX-8350 | RAM: Kingston HyperX 8GB 1600MHz | GPU: Sapphire Radeon HD 7950 Vapor-X (1050/1500) | HDD: Seagate Barracuda 1TB 7200 RPM | PSU: Thermaltake TR2 700W | CASE: Zalman Z11PLUS HF1
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/
Do you have mods on skyrim, like better graphics mods? Because I know that really brings performance down a bunch. But if you are running at 1080 or higher resolution, there is no way you can run crysis 3 at max settings and good FPS with a 7950 unfortunately.
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-469536
What drivers are you using for your gpu?
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-469538
Have you updated Skyrim? There are a lot of updates which fix some issues. Tray turning off Anti Aliasing (AA). Crysis 3 is very demanding especially on ultra settings. With that gpu there is no way you could play that game at max settings with decent fps.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-469551
err....im running crysis 3 just fine...im also running skyrim with all the dlc and high res texture pack....im running that fine too.....It feels like 60fps on both...may just be a constant 55-60 but i never dip into 30's.....im sure of it.
-Anubikai
| i5-4670k at stock until I do a custom WC loop | H80i | Asus Matrix Platinum 7970 at stock until I do a custom WC loop  | MSI Z87 GD65 | 1TB CAVIAR BLACK | 250gb Blue Scorpio | HX750 80 PLUS GOLD modular | 16GB INTEL EXTREME EDITION PATRIOT 1866MHZ | Coolermaster Storm Enforcer with two Red 20cm fans intake and exhaust |
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-469667
-Anubikai
Mine dips below 30 on max setting at times and doesn't come close to averaging 60fps unless i go to high settings then thats around what i get
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470110
wtf? really....ive kept my 4670k at 3.4ghz and my gpu is clocked just under yours....how does mine stay so constant and above yours?......
I just did a run on system spec very high and texture resolution high at 1080p and got this with fraps....
2013-07-17 13:55:11 - crysis3
Frames: 3734 - Time: 60000ms - Avg: 62.233 - Min: 55 - Max: 78
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470232
-Anubikai
When I've used dxtory (not recording) to monitor my frames i dont get anywhere near that how do you manage min of 55 do you have AA turned off
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470278
here are my exact settings.....
and
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470306
-Anubikai
oh when i was getting the results i was talking about i had everything maxed out completely, how come you only have AF at 2x also were you getting that performance in campaign or mp
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470596
I dont really see any difference visually with it high or low....does it do anything major?
@theamazingguy - i was under the assumption everyone could run at these settings and play like it do.....
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470615
On benchmarks, the 7950 runs at an average 35 FPS everything maxed out on Crysis 3.
Turn off anti aliasing
Skyrim however should be running well over 60 FPS. Update game and remove graphics mod (If any)
I'm talking about the original, 2007 Crysis, not Crysis 3. I'm aware you need a more powerful GPU in order to max out Crysis 3.
I don't have any mods and I have updated the game to its latest version.
I'm using driver version 13.5 Beta2.
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470801
ok wow...im gonna re download my copy of crysis 1 from steam....and try it out....you should easily be maxing that out with a 7950.......also im using 13.6 drivers if that makes any difference...
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470809
this guy is at 2560x1440...and he apparently gets 30-60fps...at 1080 i would be expecting 60+non stop......maybe in intense scenes it drops to 45-50 but everywhere else 60....atleast
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470816
-Anubikai
Where did you download version 13.6? The latest version on Sapphire website is 13.5.
Just so you know, I'm playing at 1280x720.
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470862
okay so you can get the 13.6 drivers from the amd website....
http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_win8-64.aspx
its the beta driver and how the holy crap are you not getting constant 60+fps at 720p.......a 7950 is OVERKILL for 720p gaming....there is something wrong withyou gpu sir. RMA that thing as fast as you can if you still can.....get another one or just drop down to a 7870 to save some money....
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470885
-Anubikai
I know, dude, that is what makes no sense. These are the only games I'm having trouble with.
I'm going to install the driver and let you know if it worked.
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470945
okay if these are the only games you having trouble iwth then your pu is fine....but i dont know why the games would run like your reporting them....im running skyrim with all the dlc and the high res tecture pack at 60fps constant......yours should do exactly the same.....
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470966
Crysis 3 rips apart even the most powerful of graphics cards.
Listen if you care.
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-470969
not really.....good systems that are taken care of by the user run crysus 3 just fine...mine for example....
-Anubikai
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-471138
-Anubikai
A 3970x with a gtx titan cant max the game at 2560x1600. Wonder how long before we get 60fps on crysis 3 on 4k. I guess your system should be fine with crysis 3 if you mess around with teh AA settings as thats  the make or break area. btw you dont have to add your name after what you say as you profile is to the left.
Listen if you care.
https://linustechtips.com/topic/36591-crysis-skyrim-fps-problems/#findComment-471415
