OK so I know this category is not about thermal compounds, but this is the best topic to put it under. My question is what is the best thermal compound out there? Also will it make that big of a difference in temperature? Also in the comments, compare the best compound to other ones in temp differences.
https://linustechtips.com/topic/365892-best-thermal-compound/
Google for comparisons there are WAY too many to just start listing.
as for best common:
Arctic Silver 5
Arctic Cooling MX4
TUNIQ TX-4
Noctua NT-H1
Innovation Cooling Diamond
to name a few
https://linustechtips.com/topic/365892-best-thermal-compound/#findComment-4956227
Proven & reliable = Arctic Silver 5
Currently most favored by pc builders = Arctic Cooling MX4
I stuck with my Noctua cooler's paste that came with it - Noctua NT-H1, and it performs well.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/365892-best-thermal-compound/#findComment-4956244
best is probably some metal compound,
best practical compound is MX-4, AS-5 is also pretty popular. I prefer MX-4 but there are loads of good thermal compounds, and as long as it's applied properly, there shouldn't be a significant difference, in the realm of a degree or two.
https://linustechtips.com/topic/365892-best-thermal-compound/#findComment-4956275
Yes. SilverStone
CPU: i7 4790k Devil's Canyon MOBO: G1.SNIPER | GPU: GTX 970 SSC ACX 2.0+ | CPU-COOLER: CM Hyper 212 EVO | RAM: G.Skill Sniper X 8GB
PSU: Corsair CX600 | CASE: Corsair 760T | MONITOR: Vizio 32in HDTV | HDD & SDD: Kingston 256GB SSD, Seagate Barracuda 1TB HDD
https://linustechtips.com/topic/365892-best-thermal-compound/#findComment-4956364
Whatever comes with your cooler because the differences are so minimal that, unless you're using chocolate for TIM or no TIM at all, it's basically irrelevant. If your cooler doesn't come with any, then I'd consider something non-conductive that doesn't take forever to "cure."
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/365892-best-thermal-compound/#findComment-4960045
