http://pcpartpicker.com/p/nqwXBm
Ok guys i decided .. i am planning on building this pc ...
is it good ??
will it run GTA V ( it is the most hard game i want to play ) in 1080p and 60FPS ?
i also want to play LoL, Minecraft, CS:GO, Battlefield ..
i am of my 700$ budget tho ..
any advice for less cost but same power ??
thank you in advance .. :D
P.S. Sorry for my english :/ still learning..
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/
Looks good, But you shoud get a Z97 board if you want to overclock, And for that build id recommend a 600 watts PSU, The CX600 is semi modular.
You could go with a lower end non-overclockable i5 and still have similar Gaming performance.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953569
so could i go with a H97 motherboard and a not overclockable i5 for same performance ??? .. could you make a build and post  it here ?? .. thank you for your help btw ... i thought that if i overclock that cu ill get like ... a very very good performance out of it ..
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953584
The performance loss isn't big considering that the r9 280x is holding you back. I would reccomend that you get a i5 4460 instead and use the money you saved for a r9 290.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953599
i would o for a i5-4490 non K and stay with the 280x .. is that a bad idea ???
also i could run this on the stock cooler .. rright ?
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953652
The stock cooler will run just fine at stock.
The performance difference between the i5 4460 and 4690 is not very big, You would still have the same gaming performance.
My Gaming PC
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953800
http://pcpartpicker.com/p/HrPHjXiam on this build right now ... 4670
and r9 280x ..
check it out
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953833
and r9 280x ..
check it out
Should work just fine, You will be able to almost max out most games, But if you overclock the GPU the PSU will probably not be enough.
My Gaming PC
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953849
the GPU overclock is going to be done for sure .. but ... what do you mean by overclocking the PSU ??? ... wtf never heard of that before .. :/ sozi am a bit new to the overclock things
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953864
I meant that a 500 watts PSU wont be enough for a overclocked 280x, I would recommend atleast 550 watts one if you want to overclock.
My Gaming PC
https://linustechtips.com/topic/365701-ok-first-gaming-pc-build/#findComment-4953877
