Ok, I'm using a switch but when running it, it shows all of the options, regardless of what's chosen.
Code:
 do{
    cout << "1. Show information on all letters." << endl;
    cout << "2. Show information on one letter." << endl;
    cout << "3. Quit the program." << endl;
    cout << "Enter your choice here: " << endl;
    cin >> num;
    switch(num){
    case 1: printInfoAllLetters(ar);
    case 2:
      cout << "Which letter are you interested in?: ";
      cin >> letter;
      printInfoOneLetter(letter,ar);
    case 3: cout << "Thank you for using the system. Good bye." << endl;
    default: cout <<"Invalid choice. Please try again." << endl;
  }while(num <1 || num>3);
  return 0;
Output:
1
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
B 0  -
Which letter are you interested in?: S
S 0  -
[-username-]$ ./a.out
2
Which letter are you interested in?: s
s 8  - xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
3
So that's what happening. Any help?
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/365675-urgent-need-help-with-a-switch-c/
Add break after each case.
case 1: printInfoAllLetters(ar); break;    case 2:      cout << "Which letter are you interested in?: ";      cin >> letter;      printInfoOneLetter(letter,ar);    break;    case 3: cout << "Thank you for using the system. Good bye." << endl; break;    default: cout <<"Invalid choice. Please try again." << endl;
I'll try this. Thanks!
