so i have always been oriented around portability
this is my curent build http://pcpartpicker.com/p/3kQGD3
i am debating on two options,
getting this case
http://pcpartpicker.com/part/silverstone-case-rvz01b
and
a new power supply
OR
this case http://pcpartpicker.com/part/silverstone-case-sstsg13b
i need something that can fit in a backpack and on an airplane and was wondering what you thought would be easier to carry
note that option 1 is almost 2.5 times as expensive as option two
https://linustechtips.com/topic/365574-case-debate-for-portability/
I'd go with the RVZ01B because it's flatter, and you said you need it to fit in your backpack. I think flat items would be much easier to pack than cubic items.....
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
but the second option is cheaper and smaller, and personally i wouldnt mind a cubic object
The node 304 is actually smaller and seems to look nicer to me just imo it also looks more sturdy
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
