http://pcpartpicker.com/p/7wXdWZ
it says my gpu wont fit in there but linus fit a titain x in their latest build log ( https://www.vessel.c...ideos/Gdb2u0UqC) so...... will it work?
Just try it. Its 1 mm You will find a way
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/365547-itx-case-compatibility/#findComment-4951637
Have you thought of this case?  It's even more compact (as in console size)
Granted, you would need one of these SFX 450W PSU or another SFX.
Compare the size of that 970 with that Titan X, it it's longer your not fine, if it's shorter, you will do well.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/365547-itx-case-compatibility/#findComment-4951668
LOL
Exceeds by 1mm
You see it fits? Fits.
followup question at random (cus i didnt want to waste a post on this)
will i be able to see an led fan through the mesh of this case in the front?
https://linustechtips.com/topic/365547-itx-case-compatibility/#findComment-4951692
it says my psu is incompatible http://pcpartpicker.com/p/8DHKLkwhy is that?
https://linustechtips.com/topic/365547-itx-case-compatibility/#findComment-4951697
The Silverstone case I mentioned, needs a SFX Power supply.  In my comment you can find one such PSU.
(Linus video on it)
https://linustechtips.com/topic/365547-itx-case-compatibility/#findComment-4951756
one thing.... titain x is 3mm smaller than gtx 970 so....... given that information will it fit?
(Linus video on it)
ok thanks, but what about the quote that i included above yours?
https://linustechtips.com/topic/365547-itx-case-compatibility/#findComment-4951775
In regards to the case i'm helping you with, the GTX 970 will fit as the 980 reference fits.
(here)
Wow...  It even supports a slim Optical drive!  Just makes it awesome :)
https://linustechtips.com/topic/365547-itx-case-compatibility/#findComment-4951790
