So i was out working today so i turned off my pc this morning and when i came home i turned my pc back on and there was a weird loud noise that kinda sounded like a fan spinning way to fast and actually i thought it was my HDD spinning alot but i unplugged it and turned it back on but it was still making that noise, so i turned it off and plugged it back in and it stopped making that noise and works fine now. So i was wondering if i should be worried about it or what?
https://linustechtips.com/topic/36526-weird-sound-from-computer/
I wouldn`t worry about it unless it becomes a frequent occurence or other issues occur with it.  Sometimes at start up the computer fans can spin up really fast for a brief period until the OS/hardware takes control of them.
My H80i cpu cooler does this on startup and will slow down to normal speed within 10 seconds.
| Currently no gaming rig | Dell XPS 13 (9343) |
| Samsung Galaxy Note5 | Gear VR | Nvidia Shield Tab | Xbox One |
https://linustechtips.com/topic/36526-weird-sound-from-computer/#findComment-471260
Yeah my top exhaust fans spin scary fast on start up. I really wouldn't worry about it
https://linustechtips.com/topic/36526-weird-sound-from-computer/#findComment-471321
It's most likely the pump. My Kraken x60 suffers from it occasionally. If that happens, shut down the system, wait for a bit and then turn it back on.
https://linustechtips.com/topic/36526-weird-sound-from-computer/#findComment-473463
