Bitspower Blocks Compatability
Go to solution Solved by Tithonius,
Nvm, just got in contact with bitspower for other stuff, and they said everything should fit fine! Thanks tho
Its honestly a pretty simple question today. I have looked around the web and i havent been able to find the answer, so i figured id ask here and see what everyone says. I have a Maximus 7 Hero board and i want to use all bitspower watercooling on it. The only way that it seems that is possible is if i buy their full cover motherboard set. found here: http://goo.gl/60lUydand i also want to cool my dominator memory with this block here: http://goo.gl/BbPL3d
Im not sure if i will be able to get them both on the board at the same time tho due to that big block on top of the motherboard blocks. so im asking to see if its compatable fo rme to use both blocks or if i am going to have to use the motherboard block without the big top part. i like the big top part because it allows there to be just one inlet and outlet instead of 2 for each block.
Collecting every single CPU in existence? Is it possible? I have no idea, but i'm sure gonna try! http://linustechtips.com/main/topic/341848-dont-throw-away-old-cpus-im-collecting/
https://linustechtips.com/topic/365111-bitspower-blocks-compatability/
Also, im looking for a 1mm 2mm and 3mm thick thermal pad. i need them to be big enough to cover the entire back of a WD Black harddrive, anyone got anywhere i can find all 3 of them for a good price? i cant seem to find thermal pads for the size i need for less then like 40 bucks :/
@Panzer003 yeah, i got the rads ordered and they should head out tommorrow! and yeah, lots to plan and lots to gather with this stuff... going all bitspower has kinda been hard.. :/ itl be good when its done tho, for sure! (and hopefully the HUGE build log will catch some attention by them for future partnerships)
nah, but on a more real and probable note, im excited, just got to work out the kinks
