I am using a Q6600 with some old mobo just for a backup. I am planning to use freenas with a 1tb red or something (have not deiced). It now has 6gb of ddr2 do i need more? Will the old system work?  one wd red or two wd blue 1tb in raid.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/364962-help-with-nas/
6Gb of Ddr2 667 good for freenas for 2 pcs? I am running a Q6600
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944083
8 GB is the recommended minimum for feenas.
How bin of an array are you planning on having?
One wd 1tb red just one drive. what would you recommend for a nas for 2-4 pcs in a home.
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944111
Will you be using ZFS?
FreeNAS' minimum recommend RAM for ZFS is 8GB.
It's minimum recommended RAM for UFS is 1GB.
You need ZFS to use Plugins like Plex & such, but UFS is fine for a basic file server.
If you aren't comfortable using ZFS with 6GB of RAM, then I recommend Amahi. It doesn't have ZFS, but it's simple and has low requirements, but still lets you use things like Plex and other plugins fairly easily.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944184
Is this good or not? http://pcpartpicker.com/p/m2C9Lk
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944243
What is the SSD for? FreeNAS uses all the storage on a device. You can't partition it. Use a USB drive. 8GB-16GB is best. It would cost less too.
Other than that, sure, that's fine. You don't have ECC RAM (it's more expensive too), so don't use Scrubs on ZFS. You can still use ZFS, but using Scrubs actually might be more dangerous than not using them.
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944262
should i get ecc or it really does not matter?
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944283
For most people, it really doesn't matter. I wouldn't worry about it myself.
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944342
Hey TheGeeker,
Regarding the storage, I would advise you to go with WD Red. It is designed for NAS, servers and RAID and has some additional features that make it a more reliable and optimized drive for such environments. WD Blue are great drives but they lack important features for RAID usage and might cause problems with drive dropouts, corrupted data and that would put your data in risk. I would suggest either going with a single 2TB WD Red or two 1TB WD Red in RAID (whichever you need). :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4944878
Hey TheGeeker,
Captain_WD.
Thanks. So this thing is going with the rest of my pcs. Im my room. which i sleep in. so i am adding more cost for these http://pcpartpicker.com/p/mNfCcf will the airflow work out. i dont know. O am going to try with one 1tb drive dont think i need anymore. can i just add one more 1tb later if needed? thanks
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4945013
FreeNAS has quite a bit of information available about hardware requirements, I recommend
you have a good look at those.
Starting point: http://www.freenas.org/whats-new/2015/02/a-complete-guide-to-freenas-hardware-design-part-i-purpose-and-best-practices.html
In general, FreeNAS can be pretty demanding when it comes to hardware.
@Vitalius and @wpirobotbuilder have more experience with it than I do though, so they might
be able to give you more detailed input.
EDIT: Just noticed there are two topics for your build, so I've merged them.
It's okay to make one topic with several questions in the same section. ;)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4945245
Yes, you can add more drives to the pool down the road. Depends on how you will manage your pool, you can either freely add the drive and it will rebuild itself, or you would have to manually back up your data externally and then transfer it back once the pool is ready to have it. :)
Captain_WD.
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4946083
You'll have plenty of CPU power, but not enough memory to be absolutely sure the system is stable. If you can get more than 8GB then you should be able to use FreeNAS.
If you can't you should check out mdadm on Ubuntu. That's decent software RAID.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4946576
- snip -
Yup, mdadm is pretty decent. For convenience, one can also combine LVM + mdadm.
There's also a rather extensive home server guide my @MG2R about setting up
a home server with Debian, which can be found here: http://linustechtips.com/main/topic/6398-howto-create-your-own-linux-home-server-using-debian/
mdadm is much more frugal when it comes to hardware requirements than ZFS, so if that's
important it might be worth a look.
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4948011
Hello! Apparently I was summoned :)
Regarding mdadm requirements: Debian + mdadm + LVM + samba + transmission (torrent client) + usenet client + sickbeard + couch potato = intel celeron 1.6 GHz single core + 512 MB or RAM :)
Which explains why I'm running an octocore avaton processor at 2.3 GHz with 16 GB ECC RAM... Oh wait, it doesn't :P
Seriously though: mdadm + LVM should serve just fine as a home storage system.
https://linustechtips.com/topic/364962-help-with-nas/#findComment-4948787
