Correct multiplier is locked... default is 21, and I go to 22. Yay! [sarcastic yay]
ok now that we got this booting, slowly increase the base clock, by 5 mhz, then boot into windows and run a 15 min run of OCCT. if it passes, add another 5 mhz and go back in and repeat. when you get a bsod, try increasing the voltage slightly and run a longer (1 hour) stress test to make sure you are stable. then repeat. keep an eye on temps. and you'll be good to go.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/364884-overclocking-help/page/2/#findComment-4943822
