Will this provide good airflow? It will be a define r5 case and the drive bays I highlighted in yellow i will be removing. You can see the specs of my soon to be build in my page and I will be using 4 140mm fans. These:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553016
Thank you!
https://linustechtips.com/topic/364847-case-airflow/
No! Put two fans in front for intake, then use all three in the back for exhaust.
This is the right advice.
If you want an explanation: the top mesh cover isn't dust filtered, so unless you do something about it, this is not ideal for an intake.
Your planned build shows an air cooler on your CPU. You want the hot air drawn out of that area immediately - since heat rises, the area directly above the air cooler is ideal for exhaust.
https://linustechtips.com/topic/364847-case-airflow/#findComment-4943010
This is pretty the ideal fan setup for %90 of PC builds.
24 fps for that "cinematic" feel
After a couple weeks of behavioral sciences at my school I can easily conclude my parents need to grow up.
https://linustechtips.com/topic/364847-case-airflow/#findComment-4943018
So what type and how many gpus will be in it? Will you also be using an air cooler on the cpu?
https://linustechtips.com/topic/364847-case-airflow/#findComment-4944295
Seems fine.
https://linustechtips.com/topic/364847-case-airflow/#findComment-4952357
