Hello, Im trying to use my wireless card since I recently moved my computer and now the internet keeps randomly disconnecting Anyone know why it would be doing this?
Specs: Intel i7-4790k | Corsair H60 | Asrock Z97 Pro4 | 4x4g Corsair Vengeance | Gigabyte g1 970 | Sandisk u110 128GB SSD | 1TB Toshiba Hard Drive | Corsair RM750 | Corsair Air 540 4 Corsair AF120 LED Purple 2 Corsair AF140 LED Purple
https://linustechtips.com/topic/363496-wireless-keeps-disconnecting/
Could be an issue with the wireless card, or with your router. If either of these are relatively low-cost, then there's your problem.
"Rawr XD"
Where are you in the world?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
What Router and wireless card are you using?
Wireless signals can get disrupted/interfered with quite easily.  Is there any wireless devices nearby? A microwave in between the router and computer can even cause interference.  Whats your signal Strength like?
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
 Michigan United States
I get full bars and the router is right above me. My router is a netgear Nighthawk x6 and my wireless card is a Atheros AR938x
Hard to say really but it's likely interference of some sort, or it could be if you don't have a static ip setup some other device could be fighting with your system for a specific network address.
So it doesn't randomly disconnect anymore but now I get ping spikes while playing like league or cs go
