Hey guys,
I recently started playing around with PS and tried to make some kind of low poly effect. Now I'am happy with how it turned out but not so happy that its not sharp at all, do you guys have any tips for me to get those sharper or a filter that would allow me to make that structure again ?
http://i.imgur.com/OVqJ2PN.jpgfor a bit better quality, note the only thing I am worried about are those blue lines that are not sharp everything else is imgur compression.
Thanks ahead
C0LL0SS0S
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/363322-need-help-with-ps-noob/
the quick and dirty way is to use the polygon tool and delete the edges
Isn't there like a filter just to make a flat surface look something like this ?
https://linustechtips.com/topic/363322-need-help-with-ps-noob/#findComment-4923051
not quite like that but take a look at the filter gallery
https://linustechtips.com/topic/363322-need-help-with-ps-noob/#findComment-4923059
