Will these parts: http://pcpartpicker.com/user/Triggatomic/saved/#view=6DW7YJfit in a Fractal Define R5?
CPU: Intel i7 4700 GPU: Gigabyte G1 GTX 970 Storage: 1TB Western Blue RAM: 8 GB GDDR3 Operating Software: Windows 10 Power Supply: XFX XTR 550W Case: Shitty HP Case From Old Pre Built PC
<p>
https://linustechtips.com/topic/362940-will-it-fit/
yes
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/362940-will-it-fit/#findComment-4918807
<p>
https://linustechtips.com/topic/362940-will-it-fit/#findComment-4918808
Yes everything will fit
"Rawr XD"
https://linustechtips.com/topic/362940-will-it-fit/#findComment-4918846
But instead of msi gtx 970, I meant Gigabyte g1 gtx 970.
doesn't matter; if PCPP says it fits, it fits
https://linustechtips.com/topic/362940-will-it-fit/#findComment-4918858
Er, repost?
Sorry I had a problem with my pc and didnt know if I posted and reposted accidently.
<p>
https://linustechtips.com/topic/362940-will-it-fit/#findComment-4918860
1 problem....... I can't find the Gigabyte G1 GTX 970 on PCPP so I will find it in amazon myself..
<p>
https://linustechtips.com/topic/362940-will-it-fit/#findComment-4918930
It doesn't matter. You can go to Fractal site to see what is maxinum GPU length and check it manually.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/362940-will-it-fit/#findComment-4921419
