My modem is in the Kitchen and I have a couple desktops in the study. Without using wireless, what device would I need if I wanted to have 1 Ethernet cable running from the kitchen to the study and then diverge to connect into the desktops? I am a little new to how networking works.
I am not a potato
https://linustechtips.com/topic/361931-help-with-simple-problem/
You'd need a switch.
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/361931-help-with-simple-problem/#findComment-4906019
Okay, thank you. So do I just plug the Ethernetcable directly from the modem into the switch. No setup required?
No it's plug and play.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/361931-help-with-simple-problem/#findComment-4906037
