Go for a good solid 850w minimum, i would run 1000w for that personally as I like alot of head room
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902313
850 should be more than enough since he is running an intel cpu, i know that gpu is powerhungry though... but as i said 850 should be more than enough
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902336
600-800 watts. Depends on how much you want to upgrade in the future.
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902369
Hello i plan to buy intel i7 - 4790k one SSD Samsung 850 EVO 500GB Asrock motherboard fatality professional i have 8 fans with led graphics card :AMD sapphire r9 290 Tri-X OC and 4x4gb ram 1866Mhz.
Which power supply is needed.
Thanks you
these people are going overboard with wattage. A nice 650watt will work. I like the evga g2 is really good for the price. 750-850 if you are going to crossfire.
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902377
1000 is superoverkill
CPU: Core i7 4770K @ 3.5GHz Motherboard: ASUS Z87-EXPERT RAM: Corsair Vengeance 32GB (4x8GB) 1600 MHz GPU(s): EVGA GTX 980 Classified SLI Case: Coolermaster HAF X Storage: Samsung 256 GB 840 Pro, 2x2TB WD Caviar Black, 2x4TB WD Green PSU: Corsair AX860 860W Display: LG 31MU97-B 4K(4096x2160) and Dell S2716DG 27in 2K 1440p 144hz, Cooling: Noctua NH-D15 Keyboard: Corsair K70 with Cherry MX Blue switches Mouse: Razer Naga Epic Chroma and Death Adder Chroma Sound:Audioengine D1 Dac and Sennheiser HD650 Operating System: Win 10 Pro
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902425
Thanks for quick replays guys just read them all , well i plan to upgrade some more but Sapphire says more thatn 750 watt , so 1000 watt corsair or ???
those are 250watt cards i believe, say 300 watt for oc, 2 is 600 watts. Unless ypu get a 150watt cpu, 750-850 watts is plenty. Is hard to go off of brand for psu because they really don't make them. Whats your price limit and location?
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902508
Price limit 200 euros location Greece :D
on my phone, evga g2 is great, corsair ax line is also. If you can afford. Seasonic x is another, seasonics cheaper stuff is goods, i use it. Antec and sliverstone have good psu in the 750 up range. on my phone so i can't link stuff.
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902536
Recommended is 750W, 800-850W if you want to have a little bit of leeway. :)
850W-1000W is way overkill.
"Rawr XD"
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902594
Ah one more thing whats the diff between ax 860 watts and ax860i watts (corsair)?
The i has monitoring through Corsair Link, so basically you can see how many watts your using through software in Windows. IMO not worth the extra money
Don't get an AX860 though, you're spending way more then you need to. For a single GPU get the XFX XTR 550/650W, if you want to add a second 290X in the future, get an EVGA 850G2.
"Rawr XD"
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902667
Well now I am confused why would Sapphire make shit up ?
My modded Air 540 build
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902681
750W is considering that it's some cheap Chinese 750W that can't actually deliver the full rated 750 watts safely.
Like I posted above, actual real-world testing with 290X systems you barely touch 400W of total system power consumption at stock speeds. A good quality 550W will be fine.
"Rawr XD"
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902699
Seems like it. I would still be scared running r9 290x on a 550W though. :D
https://linustechtips.com/topic/361644-power-supply-question/#findComment-4902710
