Need Power Cable
Go to solution Solved by manikyath,
Essentially, my problem is every power supply cable I have is 10A >. The PSU only supports 7A to 3.5A (due to the low wattage).
I'll look and see at a DIY store
I'll make sure to keep you guys updated!
if it fits, it sits, the cables are rated 10A, because they have to be by regulation.
the socket they plug into are rated for 10A, meaning the cable has to be rated that as well.
So, this is my first time exploring the forums. I'm glad I have xD.
Ok, lets get on with it.
Here's my system specs:
PSU: SeaSonic 400W 80+ Bronze Certified ATX Power Supply
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor
MoBo: ASRock FM2A88M-HD+ Micro ATX FM2+ Motherboard
RAM: G.Skill NS Series 8GB (2 x 4GB) DDR3-1333 Memory
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case
My problem is that I don't have any cords that will work with the PSU. My first one was DOA. But this is brand new. Let me know if you find a cord for it. I'd appreciate it.
You can choose really anything as long as its not $1337 ;).
Thanks :D
Gamer
System Specs
Windows 10 Home x64 AMD A10-7850k APU ASUS Strix R7 370 Overclock Edition 2GB | Corsair CX500M ASrock FM2A88M-HD+ G.Skill Ares 2x4GB
Accessories
Corsair K70 RGB | Razer Deathadder 2013 Razer Kraken PRO
https://linustechtips.com/topic/361000-need-power-cable/
Any normal PC power cable should work.
https://linustechtips.com/topic/361000-need-power-cable/#findComment-4894059
let me get this straight, you need a standard power cable?
http://www.knap-it.com/wp-content/uploads/2013/10/Type-AC-PC-Y-Power-Cord-Cable.jpg
go to a DIY store, they usually have them, expect to pay around 2-5 dollars.
https://linustechtips.com/topic/361000-need-power-cable/#findComment-4894061
all you need is a simple PC cable. super easy to get.
I have like 12 lying around :P
They are pretty cheap, if you don't get any for cheap >$10, I could sell you one.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
https://linustechtips.com/topic/361000-need-power-cable/#findComment-4894112
System Specs
Accessories
https://linustechtips.com/topic/361000-need-power-cable/#findComment-4894667
https://linustechtips.com/topic/361000-need-power-cable/#findComment-4896447
