Is ethernet over power line using the worth it. I am going to be switching rooms soon and i wont be on the same floor as my router so i will no longer have ethernet.
TP-LINK TL-PA6010KIT AV600
yes i am using some right now and mine are 300mbps cheapo versions. i get 15-20mbps on wifi up in my room and it drops out from time to time. i get 30mbps with the power line things :) (i get 32mbps plugged straight into the router)
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/360528-ethernet-over-powerlines/#findComment-4888076
It depends on if the wireless you get in the new room is good enough or not.
I myself have been using wireless with my desktop for around 8 months now, due to the close location to my router (next room over, behind 1.5 walls from my computer) and have no issues with it. (Though I will be switching to ethernet now that I have some money to spend on a gigabit switch so I can have that and my "server" connected via ethernet at the same time)
https://linustechtips.com/topic/360528-ethernet-over-powerlines/#findComment-4888082
I have a similar model and my internet is actually slightly higher download speeds  but also with slightly higher ping.
Router: 28 Ping 63Mb/s down 4,8Mb/s up
Powerline: 32 Ping 65Mb/s down 4.8Mb/s up
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/360528-ethernet-over-powerlines/#findComment-4888118
I have experience with cheaper powerline adapters, and even they were just much better than wireless. Mind you my house isn't that old, and cables are in fairly good condition. Personally, if I can't get Ethernet to the system (some people who rents is not allowed to drill holes in the walls) I go with powerline as plan B.
https://linustechtips.com/topic/360528-ethernet-over-powerlines/#findComment-4888124
Powerlines, like WiFi, depend on the room you are using them in. I always prefer to use ethernet wires but my brother likes his powerline. It works well in some rooms, in other rooms it is not as fast or reliable. I bought one from NCIX to try out and they allowed me to return it after I told them it was slower than my WiFi.
https://linustechtips.com/topic/360528-ethernet-over-powerlines/#findComment-4890070
Powerlines are fantastic if you do not have means of running proper ethernet. I'd take a powerline connection method over Wifi any day, if I was posed with having to purchase either a wifi adapter or a powerline.*
I'm lucky (heh) to have a small home where my Wifi reception all over the house is strong enough to enable full speeds for my internet (which is 75Mb on average, fibre) - so that is good enough for me. If I had issues, I would buy a powerline kit which has a wifi transmitter/receiver built in - they're a very neat way to extend connectivity range.
*Unless it is a laptop.
https://linustechtips.com/topic/360528-ethernet-over-powerlines/#findComment-4890859
