Hey Guys,
I am just trying to overclock my rig. I know the procedures and all but i need help with stability tests. Currently my overclock boots into windows but whenever i run prime 95 , the application just closes. If it gave me a BSOD then it's unstable right? But i don't know what to make of Prime95 just closing altogether. Is Prime95 at fault here or my overclock is unstable?I then switched to AIDA64 and there was no problem there.
My Config is MSI GD65 z77 Mobo with an i7 3770k clocked at 4.4 Ghz with the voltage at 1.2 volts. i Have Corsair dominator platinums 1866 ddr3 memory running at 1866 with XMP enabled.
Prime 95 version is 26.6 build 3. Any help would be great here.
Thanks
https://linustechtips.com/topic/360304-need-help-with-overclocking/
@tromedo
I'd also use Intel extreme tuning utility, OCCT, aida as you already said, and rendering a video... All together ^^
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
