Hot PSU
Go to solution Solved by flibberdipper,
I might just get rid of this supply and get a new one because it is getting old now
It's not a bad idea.
I do not know if this is normal or not but I have a 700w psu and it gets quite hot. at idle it is quite hot and when the cpu and gpu are at full load it gets very hot. I don't think its just hot air being pulled from the case because its only hot when I feel the top of the psu (where the components are)
Main PC: ASUS PRIME X299-A / Core i7 7820X / 16GB DDR4 / Palit GTX 1070 Ti / Corsair CX550F / Corsair Carbide Air 540
Secondary PC: ASUS X99-A / Core i7 5820K / 16GB DDR4 / EVGA GTX 780 ti Classified / Corsair CX500M / Fractal Define S
https://linustechtips.com/topic/360287-hot-psu/
no, it is in a fractal design core 1000 case that only has support for top mounted ones
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884835
If the PSU on the bottom with the fan facing down, and it is placed on a carpet, it will not be abe to pull any air in.
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884840
no its not, my case only supports top mounted
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884843
lets put it like this: (rough estimates)
guessing your system pulls 600 watts on full load, and your power supply runs at 85% efficiency, that gives the following:
(this isnt how this works, but its good to give a generic idea)
600 watts / 85 * 100 = 705 watts pulled from the wall. (note: the 700 watts listed isnt the "pulled from the wall" but "pushed into system" wattage)
the difference between those is 105 watts, which is heat.
those 105 watts are pulled away from the system by a fan.
can you touch the PSU? if you cannot hold your hand on it anymore, that means the casing is over 70°c (a teacher told me this fact once, its quite a good rule)
if its over 70°c, something might be wrong, but at a high load, high temps just come with it.
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884845
What PSU is it?
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884846
yes I can touch it, but its much hotter than it used to be and I doubt a q6600 and a radeon 4890 can max it out
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884862
What PSU is it?
its an old recased antec one from 2009 that I don't think is sold anymore
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884878
have you checked for dust? the more dust is in there, the less of those watts of heat can get out.
yes I was just looking for that the other day just tomake sure that wasn't the problem
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884888
I don't think It could be the case temps because the cpu only gets to 60 degrees c
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884897
When it was recased was any of the airflow path changed?
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884905
no, its always been the rear exaust style
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884916
the only thing I could think of is me having to swap out the fan last week because the old one was dying
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884932
well if ur psu is on top its gonna be sucking in all the hot air from your processor add in that card which is hot as hell lol , how is ur exaust system on that system
what do you mean by exaust system
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884938
Sounds bad. Even my EVGA unit with a heavily-OCd G3258, Radeon 7950, and GTX 480 all running OCCT small data sets and Furmark made it warm. Even though the fan in mine is super loud (air woosh) so I'm considering selling it and trying to get something better.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884943
Is there any other way that the hot air is being pushed out of your system?
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884945
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884954
The place where das hot air leaves
Oh, I have a 120mm intake on the front and that's it
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884961
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884962
no, I only have a 120mm intake at the front bringing in cold air
https://linustechtips.com/topic/360287-hot-psu/#findComment-4884968
