Communication between on a WAN
ok thanks. at least that gives me a starting point.
Okay so I've uploaded the scenario I made to Puush so you can look through it and hopefully get yours working, t's mostly based on yours with IP addresses etc
So if you look in the router configuration under static you should see what to do but I'll give you as brief / decent explanation as I can.
In router 1 you'll see that it's been told about the 192.168.2.0 and 192.168.3.0 networks along with their associated subnet mask (255.255.255.0) and what IP address to go through to get to that network
In router 2 you'll see that it's been told about the 192.168.1.0 and 192.168.2.0 networks along with their associated subnet mask (255.255.255.0) and what IP address to go through to get to that network
In router 3 you'll see that it's been told about the 192.168.1.0 and 192.168.3.0 networks along with their associated subnet mask (255.255.255.0) and what IP address to go through to get to that network
Each router needs to have that route that tells it when it gets traffic for a certain network to forward it to a certain IP address, if you only put a static route on one of the routers it'll send the packets there but the packets know how to get back.
http://puu.sh/hzIiE/0f329858ad.pkt
