MAC problems (I know right lol)
Is there a way to open a sound mixer like windows, but for mac? My buddy has a MAC and says he doesn't have one, but doesn't know where to look/ find one online to install
https://linustechtips.com/topic/35916-mac-problems-i-know-right-lol/
Try to download it somehow.
(Or just eat an apple)
What do you mean sound mixer? Do you mean the volume control?
If you go to the system preferences, there is a control panel for sound where you can adjust the input and output as well as sound effects.
Not sure if that's what you mean or not, but if you are expecting it to be like Windows where you can control volume per application, it doesn't have it built in.
"Volume mixer" is what I meant, if you right click the speaker next to ur clock in windows, I was asking if mac has those
Still not sure what you mean, but if you're playing music via iTunes Window->Equalizer gets you advanced sound controls.
Also, when you say MAC I assume you're talking about a MAC address or something. It's just Mac.
CPU: Intel Core i5 2500K | Case: Bitfenix Prodigy | Motherboard: GA-H61N-USB3 | RAM: Corsair 8GB 1333 MHz Video CardEVGA GTX 660 Superclocked 2GB DDR5
Power Supply: Corsair CX 430 | SSD: Samsung 840 120GB | HDD: 2X Seagate Barracuda 500GB 7200rpm | Monitor Asus PB238Q & Asus PB278Q
Mouse: Lenovo N50 | Keyboard: Apple Pro Keyboard | Operating Systems: Hackintosh OS X 10.8.5 & Windows 8.1
no apple doesnt have it. you can just adjust the volume for each individual application. frankly, why would you want to listen to music while watching a youtube, while playing an intense FPS where you are relaying commands to your team and watching the WAN show?
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
that requires you to think, if you have a mac, you really want everything to be stupid simple
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
Brilliant insult to those of us who use a Mac.
To answer your question, no there isn't a feature for this.
lol that is the reason i have one
