Hello
I have build my new computer.
system specs:
MB: Msi Mpower z97 max ac
CPU: I7 4790k
RAM: Geil Black Dragon 2 * 8
GFX: Msi Gtx 980 Gaming g4
SSD: Ocz Vertex 4
PSU: Silverstone strider 750w
The system is realy inconsistant, some time it is stable and some times it keeps crashing.
the ram is set to run on its xmp profil. I have disabled Turbo for the cpu in the bios.
when it crashes in windows I even have trouble getting into the bios.
https://linustechtips.com/topic/358981-system-keeps-crashing/
with crashes you mean blue screen ? if so i might be the driver for gpu also when it crashes what are you doing ?
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/358981-system-keeps-crashing/#findComment-4870412
everything stops, cant do anything, mouse ketboard screen sound not reactingt. and if I am playing a game the sound stutters, the same 0,5 sec in repeat.
but if it should be the gfx drivers, then why is it crashing when I am in the bios.
all the drivers are up to date
https://linustechtips.com/topic/358981-system-keeps-crashing/#findComment-4870431
Motherbaord Bios up to date?
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/358981-system-keeps-crashing/#findComment-4870872
