The question states that compute the range of the following real valued functions and determine if it is onto
F(x)=ln(x^2) ; x doesnt equal to 0
How does one prove this crap? LOL
I dont understand this particular question only D:
Thank you in advance for your help! :)
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/358784-need-help-with-math/
I think you didn't finish your sentence. I'm confused.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4868138
Basically the question asks us to find the range of the real valued function and determine if it is an onto function! :)
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4868151
Well x can only go from 0<x<infinity. If I recall correctly, ln(x) can go from negative infinity to infinity as well in terms of real numbers. Since the set of real numbers ranges from negative infinity to positive infinity, it should be onto. Though, you might need something more formal than that.
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4868234
You can prove it by switching the ln function to an e^x function. By doing that, you switch the range of ln(x^2) to the domain of e^(x^2). Since the domain of e^(x^2)  is all real numbers, therefore the range of ln(x^2) is all real numbers.
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4868560
If I could guess I would saw English is not your 1st language.  The function y=ln(x^2) is not continues.  I think that's what you mean but onto.
No offence intended.
01010010 01101111 01100010  01001101 01100001 01100011 01010010 01100001 01100101
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4868847
Not sure what the actual question is but the function y=ln(x^2) can not equal 0.  So the function does NOT equal all numbers from -∞ to ∞
Hmmm guys from what i understand an onto function is one that streches out indefinitely when placed on a graph.
(Is that even correct?)
When i google ln(x^2) it gives me a graph that looks like it isnt an onto function by my definition.
However the answer key in my book states that the function is an onto one.....
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4868936
Yeap! Mandarin is my first language :)
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4868937
Onto function?
GG I'm in engineering and this is the first time I've heard of onto functions.
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4869391
Hmm ... I have the same kind of homework before ... Only it's harder ... and you have to do it by hand ... And what is " In " ? I barely knew have of the functions of my calculator ...
... Life is a game and the checkpoints are your birthday , you will face challenges where you may not get rewarded afterwords but those are the challenges that help you improve yourself . Always live for tomorrow because you may never know when your game will be over ... I'm totally not going insane in anyway , shape or form ... I just have broken English and an open mind ...
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4869449
Onto function?
Yeap xD
Isnt ln transcendent, no rational values only reals.
The graph is pretty weird though.... Yes it is!
it's like the function on the calculator? You know log? It is similar to it!
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4870355
What's Log ?
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4870367
I believe onto means the question is asking if the function produces all Real numbers. Looking at the graph, you can see that all possible values of y are from negative infinity to positive infinity. Slowly, but surely will the values of y reach a very large number. The values of x do not matter.
https://linustechtips.com/topic/358784-need-help-with-math/#findComment-4870443
