I have a HP Pavilion A6512P, and I have had it for a few years and it has worked fine, but recently the audio has stopped working. I have uninstalled and reinstalled the audio driver, I have upgraded from Vista to Win 7, and I have tested the speakers on a different computer and they work and I have tried the back IO ports and the front IO ports but nothing is working. If you have any things that I should try to fix the sound I would love to hear it.
https://linustechtips.com/topic/35873-sound-problems/
The sound hardware may be dead.
https://linustechtips.com/topic/35873-sound-problems/#findComment-459584
Since you tested the speakers in another computer and they work, that's about all you can do.
https://linustechtips.com/topic/35873-sound-problems/#findComment-459590
Have you opened the laptop up? Maybe the connector of the speaker's gone loose.
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/35873-sound-problems/#findComment-475994
