Case Difference
Solved by the jolly roger,
the non windowed is more quiet, because instead of a window it has noise dampening foam, while the window is a tad louder ( its a quiet case with or without window anyways) but lets you show off dem swag conponents
Issac Zachary ·
Posted in Troubleshooting2 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
