Hello fellow Techfans,
My father asked me to build him a computer. His budget is around the 500$ and it is mainly for web surfing, online banking. And some gaming like AoE so not too heavy games. It would be nice if i could play games like CS: GO and H1Z1 on it but its not a must. The build i had in mind:
AMD A8-5600K Black edition
MSI A78M-E45
WD CAVIAR BLUE 1TB
FRACTAL DESIGN DEFINE MINI
ASUS USB-N53 WiFi
NOCTUA NH-U9B SE2
CRUCIAL BALLISTIX 8GB 2X4
SAMSUNG SH-224DB Optical Drive
CORSAIR CX430 V2 Power supply
ADATA Premier Pro SP900 128GB
I would appreciate if you guys could give me some feedback, if i need replace things.
Thank You!
https://linustechtips.com/topic/357985-first-pc-build/
-snip-
Motherboard: Gigabyte GA-H81M-H Micro ATX LGA1150 Motherboard  ($49.99 @ Mwave)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($69.78 @ OutletPC)
Video Card: Gigabyte Radeon R9 270 2GB WINDFORCE Video Card  ($142.99 @ SuperBiiz)
Case: Antec VSK-4000 ATX Mid Tower Case  ($27.98 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($42.99 @ SuperBiiz)
Total: $506.69
Generated by PCPartPicker 2015-04-30 13:55 EDT-0400
CPU: Intel i7-4790K @ 4.7GHz --- RAM: Lenovo 1600MHz 16GB --- MOBO: Gigabyte Z97-G7 --- GPU: EVGA GTX 970 FTW ACX 2.0+--- PSU: Corsair CX600 --- Case: Corsair Air 540 --- Cooler: NZXT Kraken X61 --- OS: Windows 8.1 --- Monitor: 24" AOC G2460P + Dell 19" --- Mouse: Logitech MX Perfromance --- Keyboard: Corsair K70 (Cherry MX Brown) --- Audio: Sennheiser HD558
Don't buy a GTX 980, it's overpriced! Buy 2 GTX 970s or 2 R9 290s intstead (the R9 290s would even be cheaper)
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857646
Wow, that's crazy.
My dad does all the same stuff, especially AoE, and he's going to get my 5600k + MSI motherboard pretty soon...
I can't say much for the GPU, but CPU wise I'd say it's pretty decent.
It looks like a good build, but I'd skimp on maybe the SSD and noctua cooler, and get an 860k and a dedicated GPU (260x...?)
Also @GabentheGreat this isn't a gaming computer, more of an office PC, so I'm sure he'd like to keep some luxuries..
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857649
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($93.99 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.98 @ Newegg)
Memory: A-Data XPG V1.0 8GB (1 x 8GB) DDR3-1600 Memory  ($52.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.59 @ OutletPC)
SSD- Get if you can afford it
Total: $485.52
Should be able to play csgo on here dont go with amd. And get 4 gbs of ram and up your gpu if you want.
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857688
This is what I recommend. The i5 to make it last quite a while before getting slow, 8GB RAM for the same reason, GPU can handle CS:GO very well (IDK about them other games) and it's great for the money, SSD because that amount should be able to fit all you need for a while if you don't store a lot of videos or pictures on it and you can add a HDD later or use an old one you have.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($163.95 @ SuperBiiz)
Motherboard: Gigabyte GA-H81M-H Micro ATX LGA1150 Motherboard  ($41.98 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($94.99 @ NCIX US)
Video Card: Sapphire Radeon R7 265 2GB Video Card  ($109.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($34.99 @ Newegg)
Total: $528.88
Generated by PCPartPicker 2015-04-30 13:58 EDT-0400
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857699
I don't know much about amd's apus, but I have high doubts that it can run cs:go even on lower settings. For your dad's usage it's fine (he doesn't need 8 gigs of ram though).
Yea, the 5600k could run CS:GO on high settings easily.
anyways, @colligo2 http://pcpartpicker.com/p/ssc3kL
If you want it $500 on the dot, you could ditch the Noctua cooler, but it would make the system a bit louder (assuming you'd want quiet for more of an office oriented PC)
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857707
Intel CPUs even though the 1 i mentioned is only dual core it has alot more performance per core over amd which is why amd right now sucks for cpus inless your doing a budget build. but with thoes 2 cores you should be able to play games with much higher fps then with a amd cpu for a 500$ build.
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857781
Wow, that's crazy.
Awesome, many old men play AoE LMAO. Thanks for the advice!
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857787
Alright thanks for the information. I would take it into consideration.
https://linustechtips.com/topic/357985-first-pc-build/#findComment-4857853
