I need a new pc but I don't have much experience about computers so I came here to seek help! I need a build log for a budget pc around $500. I know that it is very little in amount but I can't go higher.
Note:-
I will be playing games on the pc, browse the internet and do some editing and very specifically "Cinema 4D".
Any suggestions are welcome.Please help!!
https://linustechtips.com/topic/357729-help/
What kind of games and USD? CAD? AUD? What?
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/357729-help/#findComment-4854048
says he is from india
Then it would be rupees and 500 rupees is like... Nothing.
Current PC:
https://linustechtips.com/topic/357729-help/#findComment-4854057
If in doubt; assume USD - especially since India uses Rupee, not Dollars.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/357729-help/#findComment-4854058
nope. 500 dollars is 31735.22 rupees
-_- Can you not read? I said 500 rupees is nothing.....
Current PC:
https://linustechtips.com/topic/357729-help/#findComment-4854067
yea. but i thought that you thought he said 500 rupees not dollars. sorry if i misunderstood u :(
It's all good. I'm a bit tired and I get pissy when I'm tired xD
Anyway here is something. I don't know if you need monitors/OS and it's a little over budget. I suck at building budget stuff to so it might be awful  :P
http://pcpartpicker.com/user/CalebTheEternal/saved/#view=9HrhP6
Current PC:
https://linustechtips.com/topic/357729-help/#findComment-4854091
I am really sorry I should have mentioned the amount in rupees. It is  Rs50,000.Sorry for the wrong information!!!
that's ok. austin evans has a excellent build called the axion which is around 25394.00 rupees. here's a video https://www.youtube.com/watch?v=x7OIOnAavC0. you will have to check if the parts are available in your country however
https://linustechtips.com/topic/357729-help/#findComment-4854113
they are a little bit outdated. go for the axion
Will the pentium be enough for editing though?
Current PC:
https://linustechtips.com/topic/357729-help/#findComment-4854115
will he *edit though? besides, the G3258 is a excellent chip from intel even if it has only 2 cores and no hyperthreading. it's a budget chip so i don't think he will too much editing or any editing on that matter. just what i think though i may be wrong whether he will edit stuff or not
* error fixed
https://linustechtips.com/topic/357729-help/#findComment-4854120
* error fixed
"I will be playing games on the pc, browse the internet and do some editing and very specifically "Cinema 4D".
Any suggestions are welcome.Please help!!"
Not sure if Cinema 4D is heavy though since I don't edit stuff.
Current PC:
https://linustechtips.com/topic/357729-help/#findComment-4854122
neither do i :P
EDIT: arent editing programs gpu dependent if u change an option?
https://linustechtips.com/topic/357729-help/#findComment-4854130
It is very cpu intensive as it doesn't use the gpu. So yeah, a 4 core is a minimum requirement.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/357729-help/#findComment-4854253
