Thermal Paste Question
Solved by Reno2792,
You should probably be ok, but just check temperatures to see if there are any problems. If temps get too high, then just replace the paste.
1
2
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
play_circle_filled
Latest From ShortCircuit:
