Before I overclocked my FX 4300 to 4.1ghz, I used to be able to use heavyload to get the cpu usage in task manager to 100% load. Now what I have overclocked, the most I can get it to is 95% by using either prime95 or HeavyLoad. Even then, heavyload says it is under 100% cpu usage whereas task manager shows only 95/96% max load.
Anyone know why? Any help is greatly appreciated.
https://linustechtips.com/topic/357480-why-is-my-maximum-cpu-load-95/
i wouldn't worry about unless your cpu overheats/throttles which isn't even to speak of or fps get crazy low with stutters
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
EZ tune is telling you what it is set too. RealTemp is probably telling you it actually achieving due to automated power management.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
