please help, I need advice.
Go to solution Solved by Dabombinable,
Recently my friend and I have both built our first gaming pc's. Our specs a mostly the same exept for the motherboard and PSU. We have noticed that he gets a lot better performance in games than I do.
My specs are:
AMD FX-8350 CPU
Sapphire radeon r9 290 tri-x GPU
ASRock 970 pro3 r2.0 MOBO
Sharkoom WPM700 bronze 700 WATT PSU
He has the
ASRock Fatal1ty 990FX Killer MOBO.
and the
Cooler master G750M 750 WATT PSU
Is the different type of motherboard the cause of the difference in performance? Or is my system a bit short on power?
 P.S. sorry for the bad English :)
Yes. More than likely the VRM's on your motherboard are throttling, meaning your CPU doesn't get enough power and slows down. A 990FX motherboard is always the best choice for an FX 8350 to ensure there are no issues.
Edit: looking at asrock's website its not more than likely, the VRM are throttling. You need a motherboard with an 8 phase VRM.
My specs are:
AMD FX-8350 CPU
GEIL 8gb DDR3-1333 dragonRAM
He has the
and the
https://linustechtips.com/topic/357447-please-help-i-need-advice/
My specs are:
AMD FX-8350 CPU
He has the
and the
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
My specs are:
AMD FX-8350 CPU
He has the
and the
Motherboards does not affect performance in any way, shape or form in gaming.
He may just overclocked his CPU or GPU...
Thank you for replying :)
It's weird. On the box of the MOBO it says its ''8-core ready''....so I expected that it would work fine with my CPU. Thanks for the advice :D
Check whether either your CPU or/and GPU is throttling while gaming.
Also, you can check this thread over at OCN about AMD mainboard VRM.
It does in this case because, the CPU may be limited by the VRM of the motherboard.  8350 has a high TDP and not all motherboards work well with it.
His motherboard has a 4 phase VRM with no heatsink.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
Ignore things like that-its just there to get you to buy the motheboard. With an FX 8350 you need to go with the more expensive motherboards to prevent VRM throttling and to ensure your motherboard doesn't get killed by the CPU.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
You, sir are incorrect.
I suggest you change your job title ;)
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
