That's a good looking case.
If you're good with duct tape YES you can use the H100 with 200mm fans. Just use the 120mm fans that come with the H100 and find a use for the 200mm fans, or sell em if you can't :P
No i meant the fans in top of the case not in the rad. :D
Anyone know bout this ?
https://linustechtips.com/topic/3569-help-me/#findComment-44712
