My co driver is making NO calls. Makes it very hard to do well when I dont know what type of turn is coming up.
a few people have reported this issue, codies said they are working on it
Listen if you care.
https://linustechtips.com/topic/356511-dirt-rally-issue/#findComment-4838855
Any idea why? Seems like a really strange issue to have...
not too sure the only common denominator is that they dont have wheels but i highly doubt thats the issue.
Listen if you care.
https://linustechtips.com/topic/356511-dirt-rally-issue/#findComment-4838903
That's what you get for buying early access...
https://linustechtips.com/topic/356511-dirt-rally-issue/#findComment-4838954
Goes to show that one should do some research before buying early access games. How the game "looks" from a video that the developers shows it just the tip of the iceberg.
And you probably get a lot more help about the problem by reporting it straight to the developers. I doubt that the developers keep an eye on linus tech tips forum for bug reports.
https://linustechtips.com/topic/356511-dirt-rally-issue/#findComment-4839325
I knew exactly what I was getting into... And they already knew. I was just wondering if anyone here had found a solution already.
https://linustechtips.com/topic/356511-dirt-rally-issue/#findComment-4839474
I feel sorry for you. There bastards here with things to do with early access and that's a fact.
Mention early access and be prepared to be told how to spend your hard earned money.
Don't you fucking dare pre order either.
It doesn't matter if you tell people you know what early access is, you will still have your balls ripped of and have swimming goggles made out of them because you have no right to buy in to early access or pre order.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/356511-dirt-rally-issue/#findComment-4840773
Yeah..... apparently
https://linustechtips.com/topic/356511-dirt-rally-issue/#findComment-4843778
