G3258 OC problem
Go to solution Solved by Dabombinable,
I was expecting at least over 4.0ghz :( what about the X99 boards?
An ASUS H87M Pro can easily push an i7 4770k past 4.5GHz so you shouldn't be having problems with your Gigabyte board:
Anyway, check this out: http://www.overclockersclub.com/guides/intel_pentium_g3258_oc_guide/2.htm
Hey all,
I have a Gigabyte H97-D3H board which supports overclocking the G3258. However, I ran into some issues.
For some reason, I can never reach 4.0+ghz with my board and Corsair H60 AIO cooler.
The system won't boot when above 4.2ghz and between 4.0 and 4.2 when I run stress test the system crashes.
What could possibly be the problem and what would be a good OC profile for me?
https://linustechtips.com/topic/356423-g3258-oc-problem/
Hey all,
What are the settings you changed?
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837703
Have you changed the voltages at all?
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837709
Your cooler should be able to handle 1.3 just fine so set it to that and see how high you can get for the multiplier
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837736
X99 won't work with g3258.
Your board could get my g3258 to 4.5 so it's not your motherboard's fault
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837742
Could you explain to me why the system won't boot? It goes to BIOS but then just crashes at the starting screen (all black with the windows logo)
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837748
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837760
Complicated but I will try! Thanks! :)
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837786
The last page has the settings, and to get good overclocks you need to dive into the more advanced options. (And yw).
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4837797
Hey all,
- put your uncore ratio to 3.6GHz and try again... if you let it on auto, the mobo with just copy the freq of the CPU cores
and sometimes, often, it's the uncore that crash the overclock...
1st, reset the CMOS: UNPLUG YOUR POWER SUPPLY FIRST
Short those pins: see picture
now try that:
-everything auto except:
-CPU core freq: 4.0GHz
-Uncore ratio: 3.6GHz
go test for stability...
I have the same mobo, M-ATX version (H97M-D3H) by the way...
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4838250
now try that:
Some says the uncore ratio should be higher or equal to the frequency?
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4840726
- it doesn't matter with Haswell CPU. Some have report better Cinebench result with Uncore at 300-400 MHz lower than core...
Anyway, if you want your overclock to be stable, try my suggestion... If you want your uncore = to core, you gonna have to
give it some voltage, RING voltage control uncore ratio... The problem with your mother board, it that if I remember correctly,
the max RING/UNCORE is 1.149v and the max VCORE is 1.2v.
My mobo settings for 4.0GHz
Everything at auto except: Core at 4.0GHz / Uncore at 3.7GHz
I let the VCORE at auto because this mobo will overvolt to 1.2v + offset that way, so
you don't have to set it manually. And since it is locked to 1.2v, it's pretty safe.
Good luck
https://linustechtips.com/topic/356423-g3258-oc-problem/#findComment-4841276
