GPU frame rates dropped
Go to solution Solved by piccolodude,
So I re-installed windows, my drivers and did all the updates and that seems to be working. If there are any changes I'll let you guys know, I haven't gotten the chance to do a full test yet as I'm installing the game (Final Fantasy XIV) I'm primarily worried about right now and I'm about to go to bed. I'll up date you all if this fixes the problem I was having. Thank you all for the time and advise.
So I had gotten a virus and had reinstalled Windows 8.1 after doing that my GPU performance has dropped.
Specs:
Windows 8.1 Pro 64 OS Version 6.3.9600.17736
Asus VII Hero mobo
Intel 4790k OC to 4.6GHz
EVGA Nvidia 980 SC stock clock
Samsung 850 evo 500 gb
16 gb of G. Skill Ripjaws X 1866
750W OCZ Fatality PSU 80+ bronze
I have uninstalled the Nvidia drivers and reinstalled with no change. My curent driver is 350.12
https://linustechtips.com/topic/356376-gpu-frame-rates-dropped/
can you show a GPU-Z ID?
did you reinstall all other drivers other than your GPU?
aka Chipset,SATA?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/356376-gpu-frame-rates-dropped/#findComment-4837241
Bench scores
http://www.3dmark.com/fs/4438292ran on 3/28/15 this is after re-installing windows
http://www.3dmark.com/fs/4431820ran on 3/28/15 stock clock this too is after re-install
http://www.3dmark.com/fs/4344638ran on 3/19/15 with a slight OC done before re-install
I don't have a stock clock bench test score before re-install
But as you can see the scores are a dramatic drop
try overclocking it then bring it back to stock
I have OC it t clocks that had work before I re-installed windows and they are now unstable after the re-install
aka Chipset,SATA?
Yes I have done this as well
https://linustechtips.com/topic/356376-gpu-frame-rates-dropped/#findComment-4837444
My Temps under a load CPU and GPU get high 60' low 70's sometimes gpu with get up to 81 so I'm not having thermal throttle.
I dunno shit about overclocking and whatnot but isn't your cpu clockspeed low? yours says 799.8 mhz, mine says 3799.1 mhz in cpu-z.  Might be the problem if you didn't set your OC.properly.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/356376-gpu-frame-rates-dropped/#findComment-4837652
actually that is downclocking working
when the PC is at idle the PC will just run 800Mhz
https://linustechtips.com/topic/356376-gpu-frame-rates-dropped/#findComment-4838740
Yeah under a load it will go up, I'm half tempted to just re-install windows again to see if that will fix it :-/ Unless I can find out what's casing this problem. Before I do that I'll install the card in my other 16x pcie to see if that will fix it.
https://linustechtips.com/topic/356376-gpu-frame-rates-dropped/#findComment-4839002
https://linustechtips.com/topic/356376-gpu-frame-rates-dropped/#findComment-4841588
