My build right now:
CPU: AMD A10 7850K 4.0 GHz Black Edition  ($189.00 @ Umart)
Motherboard: Asus A78M-A ATX FM2+ Motherboard ($75.00 @ Umart)
Memory: Crucial 8GB (2 x 4GB) DDR3-1600 Memory  ($46.50 @ Centre Com)
Case: Corsair SPEC-02 ATX Mid Tower Gaming Case (84.99 @ Mwave Australia)
Power Supply: Antec Basiq 350W ATX Power Supply  ($42.00 @ Mwave Australia)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($119.00 @ Mwave Australia)
Monitor: Samsung S22D300HY 60Hz 21.5" Monitor  ($135.00 @ Centre Com)
Ok so I'm going to upgrade soon (within the next 3 months) and I was thinking of going for a R9 280 and a 500W power supply (don't wanna spend over $350 AUD with both the parts), I have 3 questions:
1. Are there any better graphics cards in my budget?
2. Any power supply recommendations?
3. Will a 500W be enough for the new build?
I live in Australia, thx.
https://linustechtips.com/topic/355894-upgrading-system/
1. Probably not.
2. 500B1: http://au.pcpartpicker.com/part/evga-power-supply-100b10500kr
3. Sure.
https://linustechtips.com/topic/355894-upgrading-system/#findComment-4831453
I have another question, whats the difference between the Windforce and normal version?
What normal version?
https://linustechtips.com/topic/355894-upgrading-system/#findComment-4831719
The graphics card, R9 280 I see a Gigabyte-WF3 version thats $10 cheaper at my store. Whats different in that version?
It would help to list the model names of the graphics cards.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/355894-upgrading-system/#findComment-4831848
This is what I see in my store's catalogue... 3G R9-280 Sapphire-OC(11230-00-41G) and Gigabyte-WF3.
https://linustechtips.com/topic/355894-upgrading-system/#findComment-4831938
Neither are the 'normal version' (What even is 'normal'?)
There isn't much difference between the two. The Windforce is a bit better but I'd suggest just going for the cheapest aftermarket 280 you can find.
https://linustechtips.com/topic/355894-upgrading-system/#findComment-4831958
Haha sorry I just meant non-windforce. The windforce is cheaper so I'll just go for that.
https://linustechtips.com/topic/355894-upgrading-system/#findComment-4832133
