Hi there i have this weird problem with my hdd i only use it to store games and stuff i have a ssd for windows and important files. the hdd sometimes just disappears and crashes my pc then on start up i have to enter device manager and scan for hardware changes to get it back. anyone got any ideas or is it new hdd time again
https://linustechtips.com/topic/35558-hdd-help/
the health status is good witch i find weird
Have you defragged the drive recently. I use defraggler which is a really good program. This might help maybe
Asus Maximus VI Extreme, I7 4770K, NZXT Kraken X60, Kingston HyperXBeast DDR-3 2400, Sapphire 6950, NZXT Phantom 820, SanDisk 120Gb Extreme x2 in Raid, 2Tb WD Green, SeaSonic X-850 Gold
https://linustechtips.com/topic/35558-hdd-help/#findComment-456736
Defrag your HDD. I personally use Puran defrag, it have settings which optimize your system making it faster and it does work. Try it out.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/35558-hdd-help/#findComment-456759
Don't know if this is your problem, but you need to leave at least 10% of the hard drive free of data, otherwise you may have issues and will be unable to defrag. I shrink my HD by 10% to leave it as unallocated space.
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
https://linustechtips.com/topic/35558-hdd-help/#findComment-456917
