+1 to the g402
Listen if you care.
https://linustechtips.com/topic/355353-mouse-for-under-%C2%A325/#findComment-4825283
Is there anything I can get for £25?
CM Storm Xornet is quite popular as a cheap gaming mouse.
Logitech G300 & G300S are also popular. The only difference is the colors. They are typically £30 but a few are available on ebay for <£25 new in box. Some people will tell you the off centre sensor is bad, I don't think it's a deal breaker (I use a similar design as my daily use non-gaming mouse, it's fine) and most reviews for the G300 are positive.
EVGA TorQ X3 & X5 might be attainable in budget, you'll have to dig up some reviews 'cause I don't really know if they are good or not.
Did you have any preference for number buttons? size? grip style?
https://linustechtips.com/topic/355353-mouse-for-under-%C2%A325/#findComment-4825604
