So I was playing GTA V and I had my MSI afterburner open and was noticing that my GPU usage was going all over the place between 70-99% which isn't really consistent. I tried playing different games to see if it was my GPU, but I was getting a solid 95-99% usage on a game like BF4. So I'm wondering if it's the game, my drivers, or my system?
Edited by Glenwing
Caps lock removed from title
https://linustechtips.com/topic/355250-gta-v-gpu-usage-problem/
I would highly suggest as much as I hate to say it, setting all your graphic settings to default UNTIL the game is properly optimized. Me and Lolzious both had a similar issue and it help dramatically even though some of the settings it changed didn't make sense/it raised them from normal to high in some cases. Try it and get back to us.
My Rig- CPU: Phenom II X4 955 3.2@3.6ghz (OC) Motherboard: MSI 790FX-GD70 Ram: 2x4GB Patriot Viper 1333@1666Mhz (OC) Cooling: Corsair H55 liquid cooler (CPU), 3x120mm 3 speedTricool blue LED case fans (2 front 1 rear), 1x200mm 3 speed Tricool turbine (top)  PSU: Corsair CX600  GPU: XFX R9 270X 1050@1150 (OC) Storage: 1x60gb OCZ Vertex III (Boot) 1x500GB Western Digital Black (Storage) Keyboard: Roccat ISKU Alien FX Multicolor  Mouse: Roccat Cone Pure Multicolor  Headset: Logitech G430 Display: LG Flatron W2353V
https://linustechtips.com/topic/355250-gta-v-gpu-usage-problem/#findComment-4824241
Ok will do :D
https://linustechtips.com/topic/355250-gta-v-gpu-usage-problem/#findComment-4824295
