Need Help Upgrading!
Go to solution Solved by EMENCII,
What Would You Prefer As A Nice Upgrade? Not As Significantly Pricey, But Would Be Not As Low-End?
Some Intel core i5 and h81 mobo, or if you want to stick to AMD you can pick a FX cpu and AM3+ mobo... Though the graphic power would be less than GPU+APU... I'd buy in a kinda short period of time also a 750/750Ti/R9 270, if you can...
So I Need Help Upgrading. I FINALLY Figured Out That Dual-Core Isnt The Best.
https://pcpartpicker.com/user/TGCARLO13/saved/tLsj4D
^^^ So Thats What I Might Go To Next. Idk Yet Only Cos This IS My First Build.
But Im Running...
CPU: AMD A4-6300 3.7Ghz Dual Core
Thats The Only Thing Thats Changed Compared To The List.
BTW!
I Am a Noob To This, So I Dont Know How To OC Yet, Or All That Crossfire Stuff I Keep Seeing.
I Dont Under Stand How To Do All Of That Yet...
If Somebody Could Easily Help On Whats A Good Next Step Upgrade For That Part(Or Parts)
Let Me Know. Ill Be Very Helpful.
https://linustechtips.com/topic/355221-need-help-upgrading/
@tgcarlo13
If you want to change only the CPU that's the best you can choose, without changing the motherboard, and seen your gpu you really should set the APU and GPU to work together, it will be a huge help
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4824000
First off, welcome to the forums ;)
Next, let me get this straight... You already have all of those parts and you will just be getting the CPU, or you are getting it all?
That is an APU, (a mixture of a CPU and GPU so I would not get that and I GPU)
If you are building that, I would get less ram and get the R7 260X instead.  I would also get a FM3+ MoBo and CPU instead.
If you are just getting the CPU I would get the AMD A10-780
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4824002
@tgcarlo13
Well, I Want To Upgrade Even If I Have To Change The Mobo. But, Is That Having Something TO Do In The Settings To fix the APU and GPU?
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4824024
So All Of The PArts On My PCPartPicker, I Have Except The CPU which is the A10. I Have an A4.
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4824032
If you want to go more high-end, it will cost you more than picking that CPU alone... Depends on your budget...
As for the APU/GPU you need to go in the graphics control panel, i dont know anything else though...
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4824037
Than get the AMD A10-780
NOT the AMD A10-7850K
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4824051
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4824062
https://linustechtips.com/topic/355221-need-help-upgrading/#findComment-4826326
