I've been putting together a budget computer build for myself for some time now, and I've run into a difficult decision (or at least I think so lol). The two processors I have to decide between is an AMD Athlon X4 860k and an Intel Pentium G3258. The reason I have difficulty choosing between the two is this:
Athlon X4 860k
+ Overclockable quad core
+ Better Passmark rating for less than a $10 difference
- FM2+ socket pretty much restricts me to APUs unless I upgrade the entire mobo
Pentium G3258
+ Larger upgradeability with its LGA1150 socket
Should I concentrate on performance now and upgrade the CPU/mobo together, or sacrifice a couple cores for the sake of upgrading?
Here's the Passmark comparison link: http://www.cpubenchmark.net/compare.php?cmp[]=2362&cmp[]=2267
Here's the build I have down so far (I have it set to AMD right now for price reasons): http://ca.pcpartpicker.com/user/Lampy314/saved/66xNnQ
I'd like to keep it around that price range, if possible, so around $750 CAD before taxes. Changes to the build are welcome, but I'd prefer to hang on to the case, if possible.
Thanks in advance for your help. :)
https://linustechtips.com/topic/355205-budget-processormobo-help/
I'd get the Pentium. It's overclockable and you can upgrade to an i3/i5/i7 later. Also, why a Wi-fi adapter?
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
@Lampy
What is the purpose of the build?  Gaming?
Anyways.. you have the budget for an i3, and that is by far the best processor within your budget.
PCPartPicker part list: http://ca.pcpartpicker.com/p/wWVvkL
Price breakdown by merchant: http://ca.pcpartpicker.com/p/wWVvkL/by_merchant/
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($138.98 @ DirectCanada)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($83.98 @ NCIX)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($69.81 @ DirectCanada)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  ($63.98 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($199.99 @ NCIX)
Case: Thermaltake Commander MS/I Snow Edition (White/Black) ATX Mid Tower Case  ($54.75 @ Vuugo)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($54.99 @ NCIX)
Total: $726.43
Generated by PCPartPicker 2015-04-26 02:14 EDT-0400
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
@Lampy
Total: $726.43
A little over my budget, but definitely something to consider. Keep in mind that I live in Canada, not US, so pricing is gonna be different.
got any parts u can salvage from a old computer
that cuts cost down pretty good
save alot of money if u dont gotta buy a case and hard drives
can put money saved into better processor
No previous computers I can salvage from. I'm upgrading from a laptop, so I'm basically starting all from scratch.
i'd dump the ssd , heat sink, fan , mobo , chip
find a cheaper case
try to find a cheap i5  or i3 if ugotta and mobo with heat sink included
and just upgrade the fans and heatsink later
dont go fm2 lol it wasnt good when it was new
if u get a 50 dollar case and should leave with 300 for mobo and chip
maybe find a combo pack
something like this
http://www.ncix.com/detail/ncix-bundle-deal-asus-b85m-d-ca-107845.htm
not sure if heatsink included with intel chips u might find somethin cheaper i never looked hard
Consider the i3 over the pentium; some games don't run in 2 threads or shutter
This is a CPU chart in GTAV
http://static1.gamespot.com/uploads/ignore_jpg_scale_super/92/929129/2847596-8988251569-gtav_.png
look how the pentium has minimums of 8-9
AMD 860K @ 4.3GHz ; Kingston HyperX Fury 2400MHz ; Asus A88XM-Plus ; Sapphire R9 270X 2GB ; 600W Tacens Radix VII AG 80+Silver  ; Cooler Master TX3 Evo
I did use Canadian pricing. This is the build you should get. If you have $750 CAD, this is under budget. You won't get a better setup than the one I built for you.
